Hey Y'all,
New to this website and I'm very impressed with the knowledge and helpfulness of those posting advice and help for those of us not as up to speed regarding Kubota Tractors. I've been lurking and gathering information for a few weeks and I now think I have enough to get started with my new project.
I have inherited a Kubota B1750 tractor with the engine in a state of partial dis-assembly and need some assistance and guidance. Any and all help and advice is welcome, so lay it on me.
To start off with I'm mostly looking for assistance with the Injector pump. It "don't not, ain't not, got none."
I was told that it was determined that the internal parts were too rusted and pitted to be be rebuilt with an expectation of a long service life. A rebuilt replacement pump was to be installed but that never happened. So now I have a great little tractor without an injection pump.
Any knowledgeable, hands on experience type of advice regarding the correct injector pump, shims, timing, etc., and installation of same and the correct installation of the governor springs is certainly welcome. Hoping to find a replacement pump asap to get the tractor back in running condition.
I'm unsure of the correct Kubota part # for the correct injector pump for my engine. Lots of Kubota 3 cyl. engines and pumps out there.
I have determined, correctly so I hope, that the pump for the D950-TD is is either; #15381-5101-0 or #15531-51012
Anybody know for sure?
The prices I have seen for a new pump are wicked scary! Rebuilts, around the internet and Ebay, for $450 + seems a bit out of my price range right this minute. However, I do want to obtain a known, good pump or a rebuilt that's been done correctly, bench tested for pressure, etc.
The engine is a D950DT, pretty sure. Got that from online research regarding the the "927660B" casting # on block, at the intake side, rear, location.
"K5C 0411 with an 8 above the 11" - Casting # on the Head, intake side.
"9N" - Casting # on intake side of block, at rear, under rear intake port.
I'm a bit confused as to the exact way to get the 2 springs back into the correct orientation between the Comp Lever and the Fork Lever.
I finally found the 2 unattached springs for the governor assembly.
The diagram shows them connecting to each other and the ends of the small spring connecting to the Comp lever and the bigger spring to the Fork Lever. What is the point of that? Won't the smaller, weaker spring will always "give" before pulling the bigger spring?
In looking at the Kubota diagrams regarding the governor assemblies;
There are 2 governor springs (#2 and #3) between the #4 Comp Lever and the #13 Fork Lever.
The # 2 spring has a curved "hook" at one end and a "straight hook" with ends bent at 90 degrees at the other end. See pic.
Which end goes where?
How is it possible to get the big spring attached to the small spring and then hooked to the comp lever without loosing / dropping them before placement of the Comp lever plate?
My fingers aren't that small! There has to be a trick to it...???
Looking forward to my new project.
RP in NC
RP in NC
