Hi everyone first post and looking for some info already. I just found this site last night. I have been looking at Kubotas and I found one that the woman's husband died a couple years ago and it has set in a pole barn for that period of time. She wants to sell it and I was wondering if parts were still avaiable and what to look for on it. I drove it around and I was surprized that it started up. Here is a general des of what I saw when I looked at it. It needs all new tires, has 2600 hrs on it. has sat outside a lot as the paint is faded and plastic is almost gray. The metal is in good shape no big dents, It has rear remotes and there are no oil leaks as the cement was clean. It run very good and transmission is smooth. What would you pay for something like this or should I leave it be. Did they have any problems with this model tractor. Other than what I listed is there anything else I should look at. Thanks alot
Ike,
if you have not been here :
http://www.tractordata.com/farm-tractors/001/3/0/1307-kubota-l4200.html
good info.
tires will be expensive! metal and plastic parts should not be a concern. I wonder if she has any records of when he changed fluids and what not.
as for a price - here is a link :
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=7521455
that one has a butt load of hours on it too............
I would ask her WHAT she is thinking........and if she pushes you to come up with a price, then start with a price that you feel comfortable with.
As for what to look for.....
check all fluid levels ---
look at zerks - still should be grease showing
if you buy it - might ought to dump the fuel - not that diesel goes bad, but up the in your cold climate, it could have gelled, it might have algae growing , hell who knows.
check all meters too - did you allow it to get "hot" check the radiator up close. Someone who takes care of their stuff keeps the little things cleaned up well.
if you have time - send us some pictures - they do tell a good story.
that is beast of a tractor! It will do a lot! As for problems - I do not know of any - but others will chime in and tell you more about that model and what to look for.
