hyd. oil cooler
bmisch01
b3200
Sep 6, 2013
10
wellsburg, wv usa
Has anyone installed a oil cooler on their hydros. I have a b3200 & after using tractor hard for a while I noticed a slight drop in hyd. tractor seems sluggish & I can smell hyd. fluid & it is hot , wanted to see if anyone has this same issue
2,913
I am not familiar with the B3200 - does it have a cooling fan tucked up under like the BX series? If so - check that and make sure it has all its fins!
9,744
That model does not have a fan, but it already has a hydraulic oil cooler. ;)
I would suggest changing the filter and fluid, and clean the radiator and oil cooler.
vickark
L3200, fel,backhoe,sgr 1060 grapple, boxblade, lp bush hog,post hole auger
Jun 16, 2013
31
Wolfman, on my l3200 the hyd. cylinder on the main boom of the backhoe gets so hot I can't hold my hand on it after a few hours of digging stumps.
should I need some type of cooler on this unit. I hate to have all that heat attacking the seals and o rings.
By the way, I was up in Sandpoint last month delivering a motorhome. Beautiful place and i'm envious of the "North 40" store. wish we had one down here.
Thanks
