Thanks Shaun.
Fortunately, I can spread the project out over a long time. 99% of the year, the stream is only 3" deep and 2' wide and with a rocky base that you could wear sneakers and walking carefully, not get you feet wet. But that other 1% of the year, it can be 4' wide and three feet deep.
Because of the location, getting any size of trailer other than a garden tractor trailer back there is near impossible. Which has a lot to do with why I bought the BX25D. There is just enough space between trees to get about and I can make to a 180 with five or six back and forth turns.
I figured at first and suspect it will be as discussed earlier in this thread. Bucket flat on the ground against the pile that is dumped by the delivery truck. Then 'hike' the rock into the bucket. Drive to the side lay the bucket down, stand in the stream and take rocks out of the bucket and place them and build up the wall.
Down stream to my pond, I built this wall, took nine months, when I was younger and healthier.
No picture of the area but if you look to the left of the first picture, you can see the curve (just past the sand bags). The ground to the right is being excavated out about 30' in.
The first picture shows the completed wall and a a bridge I made to cross the stream. 75' upstream (behind me when I took the picture )of the bridge is where I want to place the rip rap.
