L 245 DT rear axle
rrawhide
L245DT
Apr 15, 2010
springville, ca
when replacing an axle on a Kubota L245DT tractor is there torque specifications that are needed when tightening the axle nut? OR should we not be concerned and just tighten to tight and then back off a turn? help?
Here's the problem, I have a 1978 Kubota L 245DT tractor. Bought in 1979 with 23 hours (900 hrs now). Prior owner laid tractor on side one and slightly bent axle. Have replaced bearings and shims 2 times in last 30 years. This time, however, the axle broke. Found a replacement part and are ready to put back together. Then started wondering about the torque specs on the axle nut.
By the way - here are the places that I got my parts from:
left axle
Myers Ward Tractor & Equipment
131 W. Riverdale Ave
Riverdale, Ca 93656
1-800-344-9494
call Carlos
This is about a 100 acre lot with many tractors and forklifts for parts. THEY HAD MY PART. Kubota wanted almost $600 - - bought for $175.
All other parts ie bearings, collars, shims, nuts and stuff came from:
www.goldeneagledirect.com
Hope this info helps some of you looking for parts and stuff.
Thanx for your assistance with the torque specs.
rrawhide
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
rrawhide - welcome to the OTT!
Thanks for posting the link ifnormation for parts ans such, the more the better as far as research.
getsmartt - thanks for stepping up with the torque information, very nice!
Swamp 62
L245DT
Jun 3, 2014
Lowville NY
left axle
Riverdale, Ca 93656
1-800-344-9494
call Carlos
rrawhide
How did you get the bearing off the axle, are they pressed on?
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Old 06-03-2014 #5
I wouldn't hold your breath on getting an answer from him.
It's been 4 years since he was last on here:
Hi North Idaho Wolfman...saw the message above and grinned.....had to post this project I'm currently working on.
So......do ya think I could just weld this up after I get it taken apart?
Allyn, WA
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
670
278
Herald Calif.
Hello Dave
If you find you can***8217;t repair the axle housing I have good used as well as new housing. Good luck with your project.
Lance
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Hi Lance.....just PM'd ya....thank you Sir.
8,744
You can weld that one, it's not cast! :D
But yea if it's too bad Lance can hook you up! ;)
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Got the cracks welded up.....waiting on the gasket and axle seal to get here to put it back together. :)
8,744
Looks like you only welded the top half, I would have recommended running a continuous bead all around, because you have now stressed the bottom half with the lack of heat and the top pulling, you could very well have made the crack travel to the other half.
But that's just surmising as you're there and you can see better in person than a picture can show. ;)
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Good to know, I'm gonna go ahead and do that. Thank you sir for your insight.
