I've done plenty of coolant flushes in mostly the automotive and powersports world, but usually I do it is as PM instead of a response to a problem.
My Kubota L305DT is getting warm when at PTO Operating speed and tends to stay up there until I throttle back and reduce the load. I've had a slight amount of coolant boil over and after inspecting the radiator, the cores look to be a bit scaled up and in need of a good cleaning. So my question is - who has used what and what do people recommended? I'm looking for a chemical additive (or different process than garden hose flush) to aid in getting the cooling system clean and operating efficiently again.
There's a bunch of different home remedies and off the shelf "mechanic in a bottle" solutions
so lets here some opinions!
To cover the bases about the overheating, here's what I know about the situation:
-Screen and fins are clear
-Haven't pulled the thermostat, but this isn't suspect because the temps regulate back to normal and stay there. I can also sustain the "high temp" where it is at based on load and always bring it back down by unloading the tractor. I could always pull it and check it on the stove, but I need to clean the system regardless
-Water pump appears to be circulating coolant through the radiator properly, whether it's "up to spec" or not, I can't verify. I am doubtful this is the problem.
-Head gasket isn't in the mix as I'm not getting coolant in the oil/white smoke out the exhaust/black floaties in the coolant/or over-pressurization of the coolant from combustion gases
-Have checked temps with a different gauge and am getting up to about ~220F before I start lowering the load. It probably could go higher, but i don't push it at that point
-Oil has been changed recently and is still clean (not overheating from the engine oil)
