has anyone installed a block heater (frost plug or otherwise) on a 6100? i would love pictures or description of how you did it.....
thanks
Hunter
thanks
Hunter
Wolfman, wouldn't this be the one Skippy1369 would want for his B6100?
http://myfarmparts.com/electrical-c...eater-fits-b1550-b1550hst-b1700d-p-20148.html
You really don't need to do that, the hose line model has a thermostat built into it.I got one of those 1 1/4 block heaters for the lower rad hose - easy to install.
But it's rated at 375 watts, which I thought was way too much for that SMALL 12 HP engine.
So. I made up a electric cable that had a diode in line with one of the wires. That way I've cut down on the power - now runs about 100 watts which is plenty to heat up the engine.
Miro
That one is a super easy install, drain the radiator from valve on bottom, remove a freeze plug on the left side of the motor, drive in the threaded adapter, install the heater, refill radiator, done.
Here is how you get the freeze plug out.
These guys have it for cheaper than anyone right now:
http://myfarmparts.com/electrical-components-c-30_534/kubota-block-heater-p-6893.html
How do you to get a freeze plug out?Here is how you get the freeze plug out.
