b8200/JLG rear rim tire conversion solution
11,290
If your going to use them on the rears of a tractor it's going to beat the crud out of you and the tractor. I have a set of those on the front of my L3450, they work great on the front.
camarokiller6
kubota b8200hste turbo. bobcat 773
Jul 1, 2014
12
hookstown pa
OK finally got the adapter plates finished and welded in place and tires/wheels mounted on the tractor...
The may beat ya up a little I haven't noticed to much of a change myself... But they diff. Didn't beat up my wallet
5,692
That wouldn't be a built 300ci 6 with Cleveland head would it???;)
jeffb
2010 Grand L5740 HST, LP RCF2072, JD Z810 54"
Oct 28, 2014
22
Monett, MO
I did buy the tires with all the orange paint on them I think the power washer will remove it
Dang, good luck getting it off. Looks like someone let their 5 year old help them paint the wheels.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Soft wire brush on a grinder will do. They are filled tires so it's not like you can pop them!
Easiest solution would probably be just citrus cleaner soak.
camarokiller6
Jul 1, 2014
12
hookstown pa
Ya the company I bought them off of had them stacked 2 per pallet orange side down...weighing in at hundreds of pounds each I didn't bother trying to flip one over. And in fortune for me the offset on the wheel put the orange side out on my application.. But I have test them out several times this week no problems or issues and it goes like a tank...very happy
