L185 Leaking Oil
ncridgerunner
BX23, finish mower, bush hog, box scraper, blade scraper, fertilizer spreader
Mar 31, 2013
78
Marion, NC
My friend's father gave him a Kubota L185 tractor with about 1500 hours. This tractor had only been started a few times in the last 25 years. I have been helping service his tractor with fluids and filters. It starts and runs good however after cleaning a great deal of oil gunk off the engine I found it was leaking oil from two places. The "valve cover gasket" was easy to fix but it is also leaking a good bit from what on a car would be the head gasket. Oil slowly seeps out at idle but bubbles out at higher rpm's.
I did not see any oil in the coolant when we changed it out and I didn't notice any coolant in the oil when we changed it. The radiator was full when we picked up the tractor but I don't know if anyone added any before we picked it up.
Not being very familiar with diesel engines does this sound like a type of leak caused by a failed head gasket?
5,129
Most Kubota engines do have a oil feed that goes up threw the head gasket and some are sealed with an O-Ring on it.
It's possible that if it's leaking from the head gasket that it's bad.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Tell your buddy to hang on to that tractor - they are good ones! Pictures??!
ncridgerunner
Mar 31, 2013
78
Marion, NC
It will be a few days before we can work on it again and I will try to get some pics. The leak is at the left front corner of the engine directly behind the generator. I can see it bubbling out by using a flashlight and getting in just the right angle to see behind the generator so I doubt I can get a decent pic of the actual leak.
ncridgerunner
Mar 31, 2013
78
Marion, NC
there is the oil feed for the head, as wolfman said its a o-ring there.. but you have to remove the head and change the gasket with the o-ring.
there is a photo of the oil feed line.
Thanks alexisferos! That is the area of the engine where the oil leak is coming from. I was having a difficult time understanding how the oil could be leaking and not seeming to have cross contamination of the oil and coolant. It must have found a weak spot in the head gasket to the outside.
How difficult is it to pull the head? Is there a tutorial for this procedure you would recommend? I've done a little work on gas engines but none on diesel. Thanks again.
5,129
I think working on diesels are easier than gas motors. It's not the head gasket that seals that oil port it's an O-ring so be very mindful of that when you tear it apart and look for parts, also note if it has one gasket or two and there position, some have a plain metal shim and a sealing gasket. Go here and download the service manual, it will spell out bolt torque and adjustments. http://kubota.servicemanualvault.com/Kubota-L185-Service-Manual.html
ncridgerunner
Mar 31, 2013
78
Marion, NC
Thanks Wolfman. I forwarded this to my friend. I think we have decided to let a professional mechanic we know do it on the side. I'd hate to tear into someone else's equipment and make a mess. When it belongs to me, I'm willing to take more risks.
