I am having an issue with my gear box on a RCK60P mower deck. The original gear box was run empty of
the 80/90 gear oil. I have replaced the gear box and rebuilt all three spindles. When mowing the gear box
is getting so hot I can't even touch it. I have never noticed if this is normal or not. I have verified the oil
level in the gear box, verified the air pressure bleed cap is working on the gear box, made sure the blades
are torqued to the proper torque, verified the belt is routed properly, made sure the blades are not scalping
the ground, the U-joint is working properly and it's a new belt. Does anyone have an idea of how hot
the gear box should be while cutting or anything else to check. Thanks in advance!
