Zg227z no start no crank
2,767
I have a zg227z mower that will not start.Looking to find a wiring diagram.
lets get some mo' info!
Will not turn OVER?
Will not start once turned over?
Thats a gasser..... so..
you have fuel to plug?
your plug "fire" - check for spark?
you have compression?
What happened to create this situation?
It sat for a long time?
You changed something?
we be a needin' som' mo' clues!;)
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Can't help out with a diagram - possibly flat battery, battery connections, PTO switch, motion control lever switches, park brake switch, seat switch (if required for start) and adjustment of each of the switches. My red zero turn had a heap of leaves/grass built up stopping one of my motion control levers from fully sitting in place an inhibiting the start, don't know about yours, but perhaps worth a check. I seem to recall someone else here having trouble with a park brake switch recently on a similar model but don't recall the outcome. If it cranks, follow 85Hokie's post.
