ZG222 Problem
TonyB
Independence, LA
Engine acted like it was running out gas while I was cutting lawn. Started up and ran for a few seconds, then cut off. Checked and changed air filters and in-line filters. Filters are full of gas, still won't start. Clicking noise in the fuse compartment. Any help would be appreciated.
8,744
Check your safety switches. Seat, parking brake, arms, ect...... sounds like one of them is out of adjustment.
5,504
2,213
Cranks over good but won't kick off, or won't turn over at all? My first thought was fuel pump but the fuel pumps on these work kind of odd. Depending on the serial number and actual model, they work off of either a spark pulse to "turn on" the fuel pump, or the oil pressure switch. So if you're not getting fuel from the pump to the carb, check the oil pressure switch wire first. Beyond that it gets kind of complicated.
Have also seen a few fuel pumps die, mostly the older 222/227's.
TonyB
Independence, LA
Lug Bolt - the mower will not turn over at all. If it was the fuel pump the mower should at least crank - my thought. Which tends to make me think of safety switch or bad fuse. While the mower was running the fuel guage was moving from Empty to Full. Very erratic. What are your thoughts.
wpschuler
Zg222
Jul 25, 2020
Savannah, Ga
I've got a zg222 with 21 hrs on it. shut it off to clean it up and went to start. hear clicking noise, fuel gage moving up and down but it's full. Check battery voltage and battery connections everything is good 12.8 v. it is not a switch issue. Almost acting like a ground issue but the grounds are tight.
SJCar
Houston,Tx
Similar problem here.I just had a new mower deck installed yesterday by Kubota dealer. Older 222A -been great. Mowed about 2 hrs yesterday evening after Kubota dealer brought it home with no issues. Today mowed about an hour - no issues. Parked about 30 feet from a tree stump & spent about an hour burning the brush around the stump while the mower sat. Got on my ZG to put it to bed and it won't start. Clacking from engine area. After a few tries there's nothing...not even trying to `clack or click. I did take a video of the clicking when this first happened. Did your problem ever get resolved ?
