B bear15 Member Mar 6, 2020 38 2 8 Brazil, IN, USA Mar 12, 2023 #1 I am getting ready to change the oil for the first time in my 2022 ZD 1211 Diesel engine. The manual calls for either CF, CF-4, CG-4, CH-4 or CI-4. All I have is a CK-4. Does anyone know if the CK-4 will work?
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 11,084 3,014 113 Bedford - VA Mar 12, 2023 #2 CK-4 is a "newer" oil - when that publication was produced the oil standard was before the CK-4 standard. Read this and use the newer oil and you will be fine CK-4 oil
B bear15 Member Mar 6, 2020 38 2 8 Brazil, IN, USA Mar 12, 2023 #3 85Hokie said: CK-4 is a "newer" oil - when that publication was produced the oil standard was before the CK-4 standard. Read this and use the newer oil and you will be fine CK-4 oil Click to expand... Many thanks! So I am now planning on doing my first oil change in my 2022 ZD 1211 using: Castrol GTX Diesel API CK-4 at SAE 15W-40. Do you think this will be just fine? Thanks a bunch.
ItBmine Well-known member Equipment B2620, RTV-X1100C Jan 21, 2014 1,520 548 113 Canada Mar 12, 2023 #4 bear15 said: Many thanks! So I am now planning on doing my first oil change in my 2022 ZD 1211 using: Castrol GTX Diesel API CK-4 at SAE 15W-40. Do you think this will be just fine? Thanks a bunch. Click to expand... Yes, that will be fine. You only need to stay away from FA classification diesel oils. All your C's you listed are backwards compatible.
B bear15 Member Mar 6, 2020 38 2 8 Brazil, IN, USA Mar 12, 2023 #5 ItBmine said: Yes, that will be fine. You only need to stay away from FA classification diesel oils. All your C's you listed are backwards compatible. Click to expand... Many thanks!
