I just finished replacing a piston, bearings and oil pump. (replaced piston due to blowby caused by a crack between ring lands) I have filled the engine with oil to the correct level. After running for 30-45 minutes the oil level has increased and is thinner causing oil pressure to drop. This may have been what caused the piston/bearing failure. I changed the oil and filled to the correct level and it happened again. Has anyone else had this issue? I'm thinking maybe a gasket or O-ring inside the injection pump is leaking fuel into the oil. Outside of that it seems to run great. No smoke. I loosened the injector lines while it was running and both cylinders seem to balance out.
Thanks
Thanks
