WTB Kubota D850
jclloo
kubota international bobcat
Dec 10, 2023
tennessee
hello all looking for complete/good d850 for my old kh35 mini ex. im located in mid tn. thanks
10,479
FYI: You can use a D750, D850, D950 as they all will bolt in exactly the same.
What's your budget?
There are 2 different versions of these engines.
If you have a water pump version, you will have to swap parts over from your current engine to the new engine if you get a thermo siphon version.
jclloo
Dec 10, 2023
tennessee
yeah mine has waterpump would want 850 or 950 not downsize to 750...do you have some good complete engines?
10,479
I do have a fully rebuilt D850 with all Kubota parts.
But it's more than most want to pay.
Is your engine rebuildable?
Here is one option.
jclloo
Dec 10, 2023
tennessee
Here is one option.
yep little more coin than i can spend lol.
i can get a good used for about 1200 but i have already sent the head off mine out to be reworked and will just re-ring pistons and hopefully be good to go. thanks
10,479
Usually these engines require you to re-sleeve them to get them back into spec.
If you put it back together and you have low compression then you'll know.
jclloo
Dec 10, 2023
tennessee
heard that lol ill check it all out before i do any work got full machine shop so if i have to replace sleeves shouldnt b an issue.... thanks
