Would a 5ft box blade be to big for a L175?
Popeyecop
L175, L3901
Sep 14, 2017
20
Chester, IL
I'm needing a box blade to help maintain a driveway. Was wondering if a 5ft blade would be to big for the L175.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Try out a landscape rake first if you're just wanting to break up the top layer and spread it some. They work surprisingly well on gravel. They won't rip up the gravel and soil like a box blade and if you're drive is in really bad shape may not be the best. It can make your drive look fresh again. It will be alot easier for that 2wd 17hp machine to handle.
I use a box blade every 5th or 6th time i go over my gravel lot. The rest i just use a 6ft rake for a refresher. My 19hp and 4wd can struggle in some situations with a 5ft BB.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
I agree with a rake and gauge wheels make it even more useful. With that setup you can set the depth of your rake.
Lencho
B7100hst
Jan 21, 2017
427
101
NM
A 4’ B.B. is perfect for my b7100. I can be hard to pull when it gets full. I have 4 wheel drive so I think you will struggle with a bigger box.:)
Popeyecop
L175, L3901
Sep 14, 2017
20
Chester, IL
Thank you for those who responded to my question. I never thought about a rake, I'll see if I can find one. I still would like to try a 4 foot BB.
Thank you again.
prof.fate
75 L175, 14 toro timesaver, Landpride boxblade, countyline auger
Nov 9, 2017
155
Beaver, PA
I have an L175 and 4' landpride. Good combo.
5'..depends what you're doing. It's gonna lift the front of the tractor (the 4' makes the front light - no loader or weights on mine). Filled with dirt/gravel..yeah, you're doing wheelies. (fun but the wife won't like it)
