My controls seem to be different than what's advertised/seen on others. Are they the wrong controls?
Well, the controls I saw go straight up and away from the operator and then like 90 degree back toward operator..They look like the ones on the othr BX23S that I’ve found with search. What part do you think is wrong?
Hmmm...it looks like his levers are not even the same shape.Definitely on backwards. That’s weird.
Also check your front differential oil, it will be bone dry.must be NEW style levers ( Z shaped) mine are 'L' shped, like Gibbys. had to check....only have 650 hrs on the beastie....
the painted over Zerks is common. Carefully scrape off, buy a NEW geasegun ( Kubota only use ),do every Zerk, then 'exercise' the joints with full extensions several time, then regrease..
Also check tire air pressures....
Yes, UNLESS they changed them, on the NEWER models, with the redesigned grill, they are wrong. Also, see you have the R-14 rears. They were NOT available when I purchased my BS 23s last year.My controls seem to be different than what's advertised/seen on others. Are they the wrong controls?
