will this FEL fit my tractor
ToddC
84
Hastings, MI
I found a good deal on a allied 895 and I want to know if it will work on my Kubota m7950dt
The loader is rated for 130-190 and my tractor is only a 80hp 4x4, I just don't want to much loader where it won't work correctly
thanks Todd
8,792
That model is way too much loader for that tractor, it would load it down too much.;)
ToddC
84
Hastings, MI
that is what I thought I just needed to hear it from somebody else, now I have to spent more to get less. That's how it works sometimes
thanks for the quick reply
Todd
4,082
That's really not the case Todd cause with the right one you save on wear and tear on your machine, maybe original out lay your are but over time think of what you will save on fuel parts and labor,, bigger aint always better
ToddC
84
Hastings, MI
true I didn't think about that, parts are getting harder to find and it would be hard to replace her.
I did find some allied 595 and a s795 with Kubota brackets for my tractor, I just wonder if the s795 is still to big. They are the same price
I like the allied loaders they are priced right and lots of them
thanks
8,792
The 595 is better suited for your tractor, and if you got the optional cylinders it would actually be able to do more work with it than the 795S.;)
The 795S is a bit too heavy for your tractor, it leaves no extra room for error.
Looked it up, they also recommend the 595 and have a mounting kit for it too!
8,792
The 495 should fit it too, your going to lose a lot of lift power if you go to the 495.
Here are the specs:
ToddC
84
Hastings, MI
I'm thinking of going with the 795 it comes with the correct mounting brackets and is rate for 75-150hp mine is a 80hp FWA, it weighs 600 pounds more but can lift and carry about 400-500 less so I'm guessing that it would even out.
Is my thinking correct?
You guys know much more about this than I do.
thanks Todd
