Will RCK54-15BX mower fit a BX1800?
mfw757
BX1800
May 20, 2024
SE Texas
Looking to buy a replacement midmount mower for my BX1800 and have found a RCK54-15BX that the seller says will work on a BX1800.
Can anyone confirm they have done this without any issues?
Thank you in advance
WAS BANNED FOR NSFW PICS
5,154
You should check with a Kubota dealer, however, from my experience, the answer is almost always NO, a deck from one model tractor will not fit a different model tractor. A mower deck from a series 50,60, 70, or 80 is not interchangeable, but all decks within the particular series are usually interchangeable. What tractor number does the RCK54-15BX originally fit? The "15" would indicate to me that the deck originally was mounted on a BX1500, which is a 2-cylinder tractor built back in the early 2000s.
5,154
It might work, but the BX1500 is a shorter tractor. I don't know if that will make a difference, and I don't know where the shortness is, just that it is a shorter tractor. Ask the seller if he will allow you to try it on your tractor first.
mfw757
BX1800
May 20, 2024
SE Texas
Thank you, as it turns out the unit for sale is a RCK54-22BX so it's identical to the one I need.
2,869
Make sure the PTO shaft is the correct length - I was in the same boat a while back and had to switch the PTO shafts!!
