michmike Member Equipment B9200 HST D Apr 18, 2020 33 7 8 71 Ionia, Mi USA Oct 6, 2020 #1 I've got a b9200 hst 4wd w fel. Which front mount snowblower should I try to find to fit it and will I need a sub frame too? Any clue where to find? Thnx
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14, Apr 2, 2019 13,156 5,826 113 Greensville,Ontario,Canada Oct 6, 2020 #2 make/get SSQA for the FEL, then get a SSQA selfpowered 48-54" snowblower... ..if money's tight, make your own for <1000 Canucks.
K kenrevo Member Equipment B9200 Oct 28, 2019 62 19 8 MA Oct 7, 2020 #3 I wasn't able to find any models that directly attached to my B9200 that weren't complete worn out. I modified a B2791 subframe and am using a B2782A snowblower. I talked about it here.
michmike Member Equipment B9200 HST D Apr 18, 2020 33 7 8 71 Ionia, Mi USA Oct 7, 2020 #4 GreensvilleJay said: make/get SSQA for the FEL, then get a SSQA selfpowered 48-54" snowblower... ..if money's tight, make your own for <1000 Canucks. Click to expand... I've got a pair coming......interesting concept. Thanks. I'll look around to see which/where a used self powered sb might be available....
