I wanted to add a snowblower to my B9200 and give that models designed for it are nearly impossible to find and worn out I decided to look for a newer model and get it to fit. I figured other might want some ideas if they want to do the similar thing. I ended up getting a B2782A snowblower with hydraulic rotation and electric deflector; it came with a B2791 subframe. The subframe fit a lot better than it thought:
I did have to cutout around the bearing support to to clear the front diff:
I decided to used the mounting holes on the FEL (BF350) subframe to attached the quick attach bracket for the back of the subframe. I needed to extend the standard mounting to reach this area:
These are the mounting brackets I made:
I don't have a good picture of the brackets installed but I'll try to take one tomorrow.
For there mid-PTO, the fixed shaft was too long to allow the PTO shaft to fit. Kubota does have different fixed shaft options; mine had the longer one. The shorter shaft would require the rear bearing to be mounted on the opposite side and would interfere with the front diff housing. I cut down the shaft so I could mount the bearing on the required side and enough to get the PTO shaft installed. I welded it back together with 3 thou of run-out:
I also had to make a mounting bracket to hold the hydraulic control valve as the one for the FEL is attached to it. I decided to get a new valve and make a bracket that I can use with the FEL and quick attach hitch.
