When this sprays
jnldr
L2800
Mar 12, 2010
114
Knox TN
Probably isn't good
I assume it's my Hydraulic for bucket.
Will it effect my 3 PT
What's the fix?
Sprayed out at metal
Yooper
3901 LA525
May 31, 2015
1,461
432
NE Wisconsin
It looks like a branch wedged in between the hydraulic tubes and the loader frame? Small pinhole leak where it kinked? If so, might be possible to remove it and tig weld or braze it. Otherwise replace the whole line. Might cost a few bucks. Others will weigh in I'm sure.
jnldr
L2800
Mar 12, 2010
114
Knox TN
Ones burning a pile and pushing so that's what did it. It was the silver 90 degree coupler on the right. If it's separating there is that replaceable or is it the whole hose and fitting?
huntfishquest.com
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Spend a buck on a can of degreaser and clearly identify the problem. Hard to see at present, is it pouring oil on the ground etc.?
