Purchased these off craigs list. On the wheel hub, I put 3 4 inch long studs, locked them to the hub with locktight and a nut on the inside. Used a wheel nut on the outside, these were just thick enough to prevent the weight retainer assy from hitting the other 2 studs. Took a 1/2 inch plate, cut it round, measured and drilled out the holes for the wheel studs. Made the center shaft to hold the weights, cut to the right length, bored and tapped a hole to hold all the weights on. 45 lbs per wheel.
