Wheel bolt/stud torque (B8200)
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Can anyone provide the wheel lug/stud/bolt torque numbers for Kubota b8200 with 16" rear wheels and 12" front wheels?
Thanks.
I know, i need to get a manual.
2,737
Thanks.
here ya go :
Front wheel nuts 57-67 ft-lbs torque
Rear wheel nuts 123-141ft-lbs torque
Rear wheel bolts 145-166 ft-lbs torque
SRG
Jul 15, 2017
490
N. IL
Thank you very much. :)
Another question, can you tell me what the 8 bolts are around the perimeter of the front wheel?
6,311
It's a two piece wheel. Remove the bolts and one half of the rim comes out one side and the other side comes out the opposite side.
SRG
Jul 15, 2017
490
N. IL
That's what i thought, wasn't sure though as I've never dealt with a 2 piece wheel before. Thanks.
Had the new tires installed today.
Torqued wheels to:
Fronts, 62 ft-lbs
Rear nuts, 135 ft-lbs
Rear bolts, 155 ft-lbs
Kept the numbers in the middle to balance the possible inaccuracy of my TQ wrench.
Here's a before and after..
SRG
Jul 15, 2017
490
N. IL
Looks good. How do you know the tire circumferences are correct for your gear ratio?
Well, on paper they should be fine.
The 23x8.50-12" matches the 6-12 tire (6-12 is listed as the factory R1 AG tire size for the front of a B8200). Both have circumferences (listed on paper) of 68.9".
The 23x8.50-12 tire has a listed diameter of 22.6". Multiply that by 3.14 to get the circumference and you get 70.96".
The 12.4-16 (listed factory R1 AG tire size for the rear of a B8200) has a diameter of 37.2". Multiply that by 3.14 to get the circumference and you get 117".
To get the ratio....
117/70.96 = 1.648. Which is a 2.58% difference from the B8200 gear ratio of 1.691
Here is the calculator i used to find the percentage difference, between the two interactual gear ratio numbers....
https://www.calculatorsoup.com/calculators/algebra/percent-difference-calculator.php
Hopefully i have done my homework correct.
The only variable i don't really have control of, or know, is the width difference between rear wheels used on the turf tire and the rear wheel used on the R1 AG tire. That should change the height slightly (depending on variance), which will change the circumference slightly as well (wider wheel lowers overall height and narrower wheel raises overall height). I do not think this difference is enough to have a detrimental effect on the relationship of everything, as a whole. Guess i'll find out.
Playing with numbers (because of the wheel width variable), just for poops and chuckles....
If i add 1/2" to the height of the rear tire (theoretical narrower wheel) making it 37.7" tall, then multiply by 3.14, i get 118.4" circumference.
118.4/70.96 = 1.668 gear ratio, which is a 1.37% difference from the 1.691 gear ratio.
If I add 1" to the height of the rear tire (theoretical narrower wheel) making it 38.2" tall, then multiply by 3.14, i get 119.95" circumference.
119.95/70.96 = 1.690 gear ratio, which is 0% difference from the 1.691 gear ratio.
If i subtract 1/2" from the height of the rear tire (theoretical wider wheel) making it 36.7" tall, then multiply that by 3.14, i get 115.24" circumference.
115.24/70.96 = 1.624 gear ratio, which is a 4.04% difference from the 1.691 gear ratio.
If i subtract 1" from the height of the rear tire (theoretical wider wheel) making it 36.2" tall, then multiply that by 3.14, i get 113.67" circumference.
113.67/70.96 = 1.601 gear ratio, which is a 5.47% difference from the 1.691 gear ratio.
Seeing a 1" difference in overall height would be one heck of a stretch (pun).
I can only speak in hypotheticals here but i don't believe there will be anything near a 1" tire height difference when mounted, between the width difference of the narrower R1 AG wheel and the wider R3 turf wheel.
YMMV but that's my educated guesstimates and theories.
SRG
Jul 15, 2017
490
N. IL
So just an update.
Today was the first day i got to put some seat time on my B8200 with the new R4 Trac Chief tires. I was moving snow with my 60" box blade, we got 3-4" of snowfall. My drive is about 175-200ft of asphalt and my neighbors is 50-60ft.
Having used the OEM Bridgestone diamond tread turf tires for snow removal (2-3") a few weeks ago around Christmas, and now using the R4's, i can say that the R4's are way better at pulling an overflowing box blade on slick ground. They are also better at back pushing into piles.
No issues turning in 4wd, no binding that was noticeable, to me anyway and it engaged and disengaged 4wd easily.
So far, pretty happy with the outcome.
