I have a Herd Kasco 750S seeder that I bought very much used from an ex-coworker that isn't very good. I used it one winter on the back of the BX and it's a PITA. This winter there were a few days when I would have liked to have been able to spread sand/salt on the common driveway but with only one tractor with a snow blower on the back I wasn't set up to do any gritting. With a second tractor coming, next winter I can have the MX6000 set up with the rear snow blower and front bucket (to load sand/salt mix) and have the M6060 set up with the front snow blade and a rear sand/salt spreader, or the other way around.
I'd really like something that uses hydraulics to adjust the "spray" pattern and figure I should get on this now in preparation for next year given some of the lead times.
So what are you using to put down grit, sand, salt etc.? Do you like what you use? What would you recommend?
