Hugo Habicht
G1900
Jun 24, 2024
877
1,234
Ireland
Made a pipe for my diy diverter valve. The original, very neat Kubota solution would have more than tripled the price of the tractor, so I went for a cheapskate solution for 16 quid. Very little space with the HST pipes and the fuel tank around that area, so I needed a 60mm length hydraulic pipe with 8mm offset. After several failed attempts I had to make a bending fixture to get it into shape.
And I applied epoxy primer to my tow hitch parts.
Raining now and flooding predicted, so top coat has to wait for at least another day.
Reactions: 10 users
nerwin
Nov 13, 2024
590
1,549
Vermont
youtube.com
I have a wood fired boiler. Can you explain what is going on there? I like the nice neat install.
It's a mini split unit or heat pump whatever you wanna call it. Should keep the garage warmer this winter and during the summer have less moisture. That's the biggest issue. It's not good to have everything get hot and cold constantly, makes the tools rust and what not. If you're working in the garage during the summer it's brutal with the humidity once you open the overhead doors haha. So this mini split will keep it climate controlled during the summer as well.
I also have a modine hot dawg propane heater that will take over on the really cold night/days that might be too much for the heat pump.
So I'll see how well this works this winter.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,498
3,617
PEI Canada
Raining now and flooding predicted, so top coat hast to wait for at least another day.
Liked for the fab work and primer. Hope you don't get flooded.
S-G-R
Jun 17, 2020
1,498
3,617
PEI Canada
Fall cleanup continues. Water cart is done for the season. Dumping the two totes out.
Hugo Habicht
G1900
Jun 24, 2024
877
1,234
Ireland
No, we are fine here. Only Cork city gets flooded when there is heavy rain and strong south easterly winds are pushing the tide up the harbour. The Irish for Cork is Corcaigh, which means marsh. Not an ideal place to build a city, I think :giggle:
See also: Wikipedia Cork City
Last time it flooded the local canoe club took advantage of it.
g_man
Feb 3, 2023
278
1,277
NE Vermont
Nice job on the tight offset piece - not that easy to do (y)
gg
g_man
Feb 3, 2023
278
1,277
NE Vermont
I/m interested to hear how it works out for you in our environment - keep us posted
gg
g_man
Feb 3, 2023
278
1,277
NE Vermont
I did the 1500 Hr maintenance in the M5640 today. It included changing the two hydraulic filters but not the hydraulic oil. Takes 10 gallons. I keep 3 clean buckets for this. I have an old oil drain pan that I put a shower drain fitting in and run a pvc pipe down the bank.
One thing that really irks me is that 9 out of 10 new filters have the magnet ring all smashed up. They charge $60 a filter at the dealer. You would think Kubota could afford a 10 cent pad in the bottom of the box. Just shoddy in my opinion. I keep reusing using two good rings I have and remove the broken ones. I know, they are magnets and probably won't go any where but it's the principle - a $60 filter should be perfect.
gg
Reactions: 6 users
mdhughes
L3901DT
Dec 10, 2014
1,356
1,115
Ste Geneveive county, MO
gg
Have you thought about using the shop-vac method of changing the hydraulic filters? I just changed the filter on my L3901DT and only lost about 1/2 cup or so of oil.
g_man
Feb 3, 2023
278
1,277
NE Vermont
Yes, I have thought about it. But, I have hardly enough room to get a very looong skinny funnel into the fill opening let alone a vac hook up. Also the filters are right a the bottom with 10 gallons sitting above - seems like a partial vacuum and two filters might be a reach ?? But that is just a feel. My method is easy enough so I haven't felt the desire to try.
gg
Shawn T. W
Dec 9, 2024
364
640
SW Missouri Ozarks
One thing you'll find with heat pumps, is down to about 35° they are very low energy use efficient ... Below that the require resistance strip heaters, while 100% efficient, they will make your meter spin!
nerwin
Nov 13, 2024
590
1,549
Vermont
youtube.com
Luckily I got propane too for the really cold days. But the unit I got is designed to be more efficient at low temps than other models. So we shall see. Says "for extremely low temperatures". Whatever that means lol.
forky
Feb 23, 2021
308
332
Wisconsin
Thanks for the information on the unit.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,445
2,024
WestTn/NoMs
My understanding is the new models heat to lower ambient. There are different models for northern and southern climates, also.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
124
119
Stafford, VA
Not necessarily true with today’s technology. I have two identical split system heat pumps in my wood shop and they do not have resistive heat elements. While their efficiency degrades in lower temperatures, they work remarkably well down to 15 degrees and the though their efficiency degrades as it gets colder the models my HVAC provider choose continues to work well to -15 degrees.
Shawn T. W
Dec 9, 2024
364
640
SW Missouri Ozarks
WOW! Didn't know that ... Thanks for the update!
I sold my all electric townhouse in Arizona in 2022, it had a 13 year old unit, in the "winter" it sure would run the bill up ... Winter usually was down to 20° at night, 50's in the day . . . At 4300' elevation.
My brother has a dual fuel one in NC, when it got cold it would switch over to propane.
