Weird issues, who can help
chuck d
kubota tractor
Jun 21, 2020
ajax ontario
Hello, mine is used as a zamboni on a hockey rink. this is the issue that started 2 days ago. 4 of us drive the tractor to clean the ice. as of 3 days ago, the other 3 cant get the tractor to move more than 2 feet before it shuts off. It feels like when the seat sensor shuts you off. however.. I can drive it perfectly with no shut off.
DRIVERS GETS ON... SHUT OFF... OTHER DRIVER.. SHUTS OFF... ME.. RUNS FINE.. So we repeat and the same results.
help, I cant work all 18 hours a day that we rent ice.. LOL
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
168
76
Danville
Are the other drivers lighter than you? It does sound like the seat sensor switch. What tractor, how is it equipped? More info on the tractor will allow others with far more experience than me to offer help/suggestions.
pjoh784350
May 3, 2019
168
76
Danville
Hmm, are they shorter, maybe sit forward more in the seat? I'm sure as more people come on this morning you will get an answer?
Bmyers
May 27, 2019
3,495
4,418
Southern Illinois
I think they are angling for a tractor with a cab on it. :p
BigG
Sep 14, 2018
1,951
774
West Central,FL
Perhaps the switch is bad. You could by-pass the switch to see if the tractor remains running with the other operators. If it remains running replace the switch. If it stops again I would continue to chase a bad safety switch.
mdhughes
L3901DT
Dec 10, 2014
1,369
1,153
Ste Geneveive county, MO
Do they lean to one side or the other then they are running the tractor? The L01 series tractors are bad if you lean to far to the right the seat safety switch doesn't have enough pressure on it. Don't know if the BX80 series has this kind of problem. Something to look at.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
If you can't figure it out, just name her Christine. But then you would be the only one to use her.
BX23S
2022 Kubota L3901 FEL, BH, GRAPPLE, PALLET FORK, SNOW PLOW and Hard Canopy
Sep 1, 2018
70
41
ID
My BX does that some times when I don't sit correctly, the seat switch is very sensitive.
