Weeping Backhoe Stabilizers
trouble11
kubota b9200, bf350fel,b4530 hoe, 2002 Gmc Sierra with plow
Jun 12, 2012
232
Plattsburgh, NY
I have read a couple of posts re: Weeping Stabilizers. Mine on My 4530B have been weeping down for 10 years and I learned to deal with it. I was at Tractor Supply looking at Oil and Fluids and I found something that may help other members with similar problems. It is called Lucas Hydraulic Stabilizer and Stop Leak. I bought a gallon and put it in My Hydraulic tank and it worked Great. Of course I looked like a fool sitting on My tractor raising and lowering My outriggers for thirty min to get it in the system. I don,t know if any other Members have tried this stuff but it realy worked well for Me. No more Weeping. :)
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
The weeping is usually a sign of the seals and o-rings going bad. Your trick could be a short term fix or a seal could blow and ruin your day when the out riggers are down and you're trying to dig.
trouble11
Jun 12, 2012
232
Plattsburgh, NY
Point taken Eric,
I,ll try anything once and this stuff worked great for Me. My fingers can,t take working in -10 deg to take the stabilizer cylinders off to get them repaired and since they have been weeping for 10yrs I figured I would try it. It has something in it that expands worn seals, and IT WORKS.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Yeah, I'm agreeing with Eric.
Wondering what other long term effects the additive may have on the rest of the hydraulic system. Any chance that it could gum up the works?
trouble11
Jun 12, 2012
232
Plattsburgh, NY
I,m sorry for My post, I just thought that it might help other Members. :(
2,787
Hey,
when you mention wheeping.......you are talking about while in use? Or sitting still for a long period of time? I have a 2013 Bx25d and they slowwwwwly far over time.....and I mean slowly....it sits in a heated storage, and the cylinder can be seen by about an inch over a week of sitting....I consider this normal.
The backhoe will creep too if the pin is not in it. I consider this normal too.
So of the old guard here, tell me if you think this is a problem!!!
DonDC
Kubota L35 TLB, B7001, FEL, Rototiller, Snow Plow
Oct 23, 2012
81
Nanaimo, BC, Canada
Trouble11 No need to be sorry for posting on this site. Lots of people have ideas that are great and not so great. Time will tell. Thanks for letting us know what you have tried. Your results could be helpful to others, one way or the other. Keep us posted on the long term results. Good Luck
trouble11
Jun 12, 2012
232
Plattsburgh, NY
85Hokie,
An inch or so in a week is nothing. Mine would go from raised all the way, to the ground in a week and it was worse in very Cold weather. Now they lower about an inch in a weeks time since I put the Lucas in. I would not worry if I were You, I think Yours is normal. Mine are 24yrs old. I will keep everyone informed if I have any ill effects with the Lucas.
Jeff
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
I think "weeping" as you call it is fairly normal with hydraulic's and that is why Kubota built the pin system for our little backhoe's. My jacks drop a bit over time too but the only time I'd ever worry is if the they let go when I needed the stabilization.
This is kinda like using STP oil treatment (us mature members may recall) put that stuff in an oil burning engine (either rings or valve stem seals needed) and you could decrease oil consumption from a quart per week to a quart every other week...
Please keep us posted with results over time! Thanks trouble.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I always thought mine weeped back through the control valve. Did it with two different sets of cylinders. This spring I plan on putting a needle valve on the extend hose of each of the rams, to see if that helps.
