I have an L245. The hydraulics are functioning but weaker than they should be. I've checked the fluid and replaced the filter. The problem is worse if the 3 point lift it raised all the way up. Don't know if that means anything. There's a box grader on there almost always. Lowering the grader a few inches from full up keeps the front loader working. If the 3 point is up all the way, the front bucket gets weaker and weaker until I can't even get it off the ground. Let the tractor sit a couple hours with everything down and the front functions again. I suspect air is getting in somewhere.
Could the PTO system be involved? There is nothing attached to the PTO, but I'm wondering if power is being diverted to the PTO drive anyway?
I'm just guessing right now. What are the troubleshooting steps do I need to take to figure out what the problem could be?
