Wanting to add rear remotes for rear bank flail mower
Ridelght
2022 Kubota L4060 Polaris Rangerxp800 Ford 3400
Feb 16, 2022
434
293
Hello,
Can anyone give me good advice on what kits are out there for my L4060 ? its a 2022. Ive seen some that bypass the loader to use, not sure if I like that idea. I just have the loader now, I shoulda had them added when I bought it but some said Kubota ports belled off a lot and I dont have any implements yet that needed 1.
Id really like to add at least 2 or even more in case i want more later.
Thanks for any advice.
3,356
Hello,
You can roll your own with an inexpensive 3 spool valve for roughly $500. So easy a caveman could do it. Factory kit is about $3K - a bit more difficult but very well integrated.
PaulL
2,140
1,135
NZ
I've seen a school of thought that using the loader valve is actually better. Not saying that you don't need rear remotes for other things, but a bank mower you tend to have to adjust all the time. Rear remote levers aren't necessarily ideal to control two functions - you have to move from one lever to the other and back. Your loader joystick gives you two functions on the one stick, once you get the muscle memory it means not having to move your hand from lever to lever.
Just something to mention, obviously rear remotes would work as well.
MtnViewRanch
719
176
Lakeside Ca.
Dan, I'm thinking he has a cab. (avatar) Still just as easy? :unsure:
And the OEM units are known for excessive internal leakage.
3,356
Nothing involving a cab is easy but the takeoff point for cabin is the same as open station. Getting to it may be an exercise in sheetmetal cuts :)
Finding a place for the third party valves is probably the hardest part on both.
The OP seems to be familiar with the stories about the OEM valves.
mcmxi
4,829
NW Montana
I have three sets of factory rear remotes on both tractors and run a Del Morino flail mower with hydraulic offset and hydraulic head rotation (uses two sets of remotes) and I can't imagine running it off the loader valve.
When making adjustments I'm looking over my shoulder and it'd be awkward having to reach for the loader valve while doing that. The M definitely has the control levers for the remotes in a better location compared to the MX, but even the MX controls are better than using the loader valve.
Edit: I ran the MX and flail tonight and I need to admit that I was wrong. It's actually very easy and quite comfortable to operate the loader valve while looking over my shoulder. The loader valve is quite close to the operator so not a problem. Apologies to @PaulL for my incorrect assumptions.
MtnViewRanch
719
176
Lakeside Ca.
I have NEVER seen a decent installation of 3rd party valves on a cab tractor.
That's not to say that it can't be done, just never seen it and if there is a set out there, it most likely is a set of electric valves. :rolleyes:
3,356
Buy me a Grand L with cab and I will see what I can do ;)
Ridelght
Feb 16, 2022
434
293
yes i do have a cab. Summit has a kit with no hoses. They did say not sure on cab fitment.
This link is what i referenced about tying into the loader control.
some reason my cab has the plug just like the M series he is installing. The other joystick on that tractor looks like the Summit kit. Not sure why they would do both. I appreciate all the insight. Im lost on what to buy and where to tie in. Not a hydraulic person.
3,356
That kit is just a manual diverter valve and some hoses with quick couplers. Its not a real remote and its only one spool. You can easily do two if not 3 real remotes for that price but it requires mire work on your psrt.
Breakaway couplers are standard issue and the bracket he is using is $25 at your local TSC. Heres four DIY sets on the back of my standard L with a mounting panel I fabricated. It also has a manusl diverter like he used mounted in the middle as a on/off control for the left set of constant flow couplers.
You can also buy the very nice kUbota OEM coupler kits (second picture) for your cab tractor and install them yourself but they are pricey. Three sets is better part of a grand Just for the outlets and brackets.
As MtnView said the hard part is locating and mounting the a real remote vslve.
3,356
Here is the parts diagram for the OEM rear outlets for your cab tractor. Call your dealer and see if you can make a deal on just the parts I have circled. The whole base kit (L8396) which also includes the OEM valve mounting parts, hoses, and levers (but not the valve) is $760. Addon stacking kits (L8393 and L8394) which include valve levers (but not the valve), hoses, and the couplers are $360 each. Kubota has made sure its difficult and expensive to get just the outlets.....
Ridelght
Feb 16, 2022
434
293
Thanks I know this is a stupid question, but where is the power beyond control ? Or do I need that as well.
3,356
Here is the rest of the base kit - whole goods L8396.. Everything in those two diagrams plus the couplers pictured in my previous post costs $760 and contains the valve mounting manifold, Rube Goldberg handle kit, and the first set of outlets I pictured above. The valve is sold separately and it costs another $300. So putting the first OEM valve on the tractor is ~$1100 and add on valves are about $600. As expensive as that is its a far better value than anything Tractor Inovations is selling.
Ridelght
Feb 16, 2022
434
293
Thanks... I need to call Messicks. My dealer is terrible, My neighbor and I both had issues with them. Sounds like 3 grand but would be all oem stuff. The bleed off I have heard about, for a ditch mower wont really be a issue for me. I have 2 acre of pond shore to mow and 2 60 degree banks. Weed eating killing me. Pond is 1200 lineal feet alone.
3,356
Pilot operated check valves will cure any internal valve leakage problem but you wont have float capability.
Be prepared to wait for those kits. People are reporting 6 month delays in getting factory remotes. Messicks is quoting 70 days.....
Ridelght
Feb 16, 2022
434
293
sorry i misunderstood the pricing. i found the kit at German Bliss. Cant find the valve though.
Ridelght
Feb 16, 2022
434
293
Thanks for all the Help
Well, you are correct. No one has these in stock. 2 to 3 months out on the L8396.
Valves and stacking kits/ handles all in stock. I may look in to a ditch mower that has its own hydraulics. Run off the pto. Not sure though on reliability.
