G guske daneels New member Oct 27, 2016 3 0 0 Europa België Herenthout Nov 7, 2016 #1 I have a Kubota L1501 and wants new oil do on the gearbox. Is the gear box appart or is it part of the hydraulic portion? Where is the dipstick of the gearbox?
Tooljunkie Well-known member Lifetime Member Equipment L1501,home built carry all, mini plow blade. May 13, 2014 4,150 35 48 62 Lac Du Bonnet, Manitoba,Canada Nov 7, 2016 #2 There is an oil level plug just forward of clutch pedal. Behind right wheel is a tube with a screen behind it, and a large drain plug on low point under gearbox.
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 8,012 3,153 113 Austin, Texas Nov 8, 2016 #3 The transmission and hydraulics use the same fluid. Use universal tractor fluid like Kubota UDT or Tractor Supply Traveler Sent from my iPad using Tapatalk
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,460 11,248 113 Sandpoint, ID Nov 8, 2016 #4 Yes same fluid for gearbox and hydraulics, and yes they are the same case. Any universal hydraulic fluid will work for you.
