V1702 rear main seal
bobcat
24
San Antonio, TX
I'm having a problem finding a rear main seal for a V1702-6660 in a Bobcat 743B skid steer. Bobcat shows 2 different rear main seals, but neither of them are correct the engine (I guess it's been re-powered before I got it). Anyways the rear main seal od is 4.000" (101.6 mm), and the diameter of the crankshaft where the seal rides is 3.352" in dia (85.13 mm). I don't have the engine serial number, can't find it anywhere on the engine. Any ideas on a part number for the seal based off the measurements?
4,546
Try taking the seal to a local bearing shop. They should be able to look up the dimensions and get you a new seal.;)
4,546
It wouldn't hurt to give them a call.:) you can try napa also. I have had luck calling them and giving them the outside and inside diameters. I do it for speedi sleeves all the time :)
bobcat
24
San Antonio, TX
Only thing I've been getting on the seal from everyone is that it's going to be a seal that only can be had from Kubota. Kubota says they can't help without a serial number (they "claim" the engine serial number is also scribed into the block just behind where the injection pump is bolted on) I can't find it there either, or any other place on the block :confused: .
5,131
On the block on the right side is a cast in number it will give the ci of the motor.
I can tell you which motor it should be with that #.
There is several different motors that can fit, a V1902 is the same pattern, and is used as a common repower motor.
There is also the possibility that it has a V2203, some models came with that motor.
bobcat
24
San Antonio, TX
It has 1702 cast on the side of the block (on the same side as the injector pump), it has V1702-6660 stamped by the injector pump. The only number I can find cast on top of the head is 5 12 08 KLA. The rear main seal od is 4.000" (101.6 mm), and the diameter of the crankshaft where the seal rides is 3.352" in dia (85.13 mm).
