using backhoe
xcoastie
2008 B-7510 w/bucket and hoe
Sep 9, 2011
Northern UT
Hello All,
I am a new to me owner of a 2008 B7510-F with a backhoe and bucket.
After 7 years of snowblowing and wheel barrel landscaping I have an orange.
When using the backhoe should I have the bucket on the ground and some down pressure when digging?
Great site and looking forward to using my tractor vs the wheel barrel
Thanks
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Hello All,
Thanks
The only difference from the previous post,I have the FEL bucket in the near full tip position so the top and bottom edges are contacting the ground at the same time .It seems to hold better this way and keeps the tractor level when facing down hill.I use mainly on ground that it doesnt matter if the surface is marked.
Dave
Edit:
I knew I had a picture some where,
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
You will find that every situation is different but in most cases it's best to roll your buchet all the way over and the lift the front tires off the ground. Just remember that the lower you can keep the tractor the better the stability will be. In a place where it matters about marking the ground up leave the bucket flat. It would hold you as well but it will be easier on the soil.
xcoastie
Sep 9, 2011
Northern UT
Hello All,
Thanks for the reply's
I have since tried using the bucket as a stabilizer and works well.
Jeff
kkcomp
B3300SU with BH77 Backhoe, 5 ft rotary cutter, box blade and 504 loader with 60
Nov 1, 2012
Jacksonville, Fl
If it is possible I fill my bucket with dirt or stones before putting it on the ground. Maybe it is just me but it sure seems to have made a big difference.
2,240
I usually have all 4 tires just touching.
I set the bucket flat if in a yard, and on edge if not.
