Use for rear remotes
Big Orange
L3650 GST LA650A FEL Howse 60 inch bush hog, Kubota L 321 60 inch snow blower
Jan 11, 2014
Ripley, Maine
Dumb question? I have a rear remote mounted on top of the fender on drivers side. I really do not have any implements yet, planning on a bush hog this summer that goes on the rear PTO.
What would you use the rear remote for?:confused:
Thanks for all the input and comments this is a great site;)
TripleR
Sep 16, 2011
1,911
SE Missouri
We put hydraulic top links on our tractors. With a rotary cutter this allows us to easily adjust the height when needed and to raise it higher for easier transporting.
When doing some extremely tough brush, I may raise the back of the cutter to ease into it then lower it to finish.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
On my L3000 I use rear hydraulics for my V-rake. I also have a trail type disk that's hyd lift. I have also used it to move other implements around that I normally would have hooked to my M9000.
The average home owner may not have much use for rear remotes but they make my little tractor much more usefull than ever before.
Big Orange
Jan 11, 2014
Ripley, Maine
Any photos?
I thought I could raise the bush hog or cutter with my 3 point hitch?
Thanks for the reply
TripleR
Sep 16, 2011
1,911
SE Missouri
Yes, you raise the cutter with the 3PH, but when properly adjusted, the rear wheels(s) may not be all that high off the ground and catch on the ground going across uneven ground, ditches, RR tracks etc. Using the hydraulic top link allows you to get clearance when needed.
Big Orange
Jan 11, 2014
Ripley, Maine
Good photo Bulldog I think I get it now, well I have them if I ever need them.:)
Thanks for the replies
RobD70
Kubota L3800 HST, Land Pride PR1672 Power Rake, Land Pride BB2572 Box Scraper
Feb 22, 2014
62
Marathon, WI
I just got a L3800 and had them install the rear remotes. For me, I got a power rake, which has the hydraulic angle, so I need them for that. Another thing some use them for is when using a hydraulic cylinder for the upper link of the 3 point. Then you can adjust the 3 point attachment easy. There are other attachments in which the remote can be used for...like a stump grinder. Hope this helps.
Big Orange
Jan 11, 2014
Ripley, Maine
I like the idea of using it for a piston in place of the top 3 pt. hitch rod looks handy and I have everything to put it together other than the piston.
I might even have that if anyone thought a myers snow plow ram would work?
Thanks for all the input;)
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
531
I'm going to use mine to operate a Weber Lane WL1SS hydraulic dump trailer.
9,619
If your ram has 2 ports for fluid then yes it will work, some snowplow rams only have 1 port and they will not work.
Big Orange
Jan 11, 2014
Ripley, Maine
YUP! 2 ports looks like this might be my next project, spent this weekend welding support legs on my new to me tandem axle trailer so the hitch on the truck dose not take so much up force.
Always a project to tinker on:D
