Update: FIXED Loader raising slow all of a sudden
GunnerBob
B3300SU; FEL; 58' Tiller; 6' Mower
Apr 3, 2011
9
Utica, OH
I have a B3300SU HST with LA504 loader. While using today, it all of a sudden started raising extremely slow.
- 3-point works fine
- bucket curls fine
- FEL lowers fine
After some searching here, I tried moving the FEL and 3-pt up at the same time. Neither moved until I released the FEL control. 3-pt went up fine immediately. I then connected the White hose to the Blue connector, and the Yellow hose to the Red connector. Boom moved up at normal speed, but only up. Wouldn‘t go down. I then connected the blue hose to the white connector & red hose to yellow connector. Bucket curled extremely slowly. It seems I moved the problem, so I don’t think it’s in the loader.
Could it be a relief valve stuck? I saw that as a possibility when I was looking. Unfortunately, I can’t seem to find a WSM for my tractor.
I have some mechanical aptitude, but not a lot of experience with hydraulics. Any help/advice would be appreciated.
Bob
Update (TLDR): Replacing the female couplers (white & yellow) on the loader side fixed the problem. See below for details.
3,106
- bucket curls fine
- FEL lowers fine
Bob
Generally, if you want to swap hoses for a test, you need to swap them in pairs...if you only swapped two hoses...not a valid test, as far as I can see, but I do not know your tractor.
GunnerBob
Apr 3, 2011
9
Utica, OH
I eventually had them swapped in pairs. .
GunnerBob
Apr 3, 2011
9
Utica, OH
I may have misunderstood what you meant. I just went back out and just swapped the 2 lines for up/down. (White and Yellow lines). The loader raised fine, and lowered ok, but a lot slower than it went up.
When I put them back on correctly, the loader raised correctly one time, and then went back to the issue I’ve been having.
thanks for the input!
bob
whitetiger
Nov 20, 2011
3,065
1,512
Kansas City, KS
Is there any way to troubleshoot that? I looked on the parts diagram & could not find “quick coupler”. Does it have a different name?
thanks
bob
The quick couples are on the ends of the loader hoses, you use them the connect the hose to the loader control valve.
6,333
thanks
bob
First, I think you did trouble shoot it already. You swapped the lift pair (Wh/Y) with the curl pair (R/Bl) and moved the problem.
Second, whitetiger has forgotten more about Kubota tractors than I’ll ever know. Smart guy with a lot of experience turning wrenches on these.
The quick couplers are the hydraulic fittings you use to connect/disconnect the loader. Male and female halves.
On my loader, the female half is on the loader. Male on the tractor.
Betting it’s a female coupler on that circuit. I’d change both of them. Wouldn’t do the other pair, unless you deem it prudent.
PS - I see TheOldHokie also replied. He’s a real hydraulic expert here. Very smart fellow also.
4,797
bob
Swapping lines doesnt tell you much if you dont understand the operation. I dont know the specifics of that valve but here is how most Kuboat loader valves operate:
  1. The bucket work port sends pressurized oil to the cylinder to curl and return oil from the cylinder is sent to tank. All down stream functions are blocked.
  2. The other bucket work port sends pressurized oil to the cylinder to extend and return oil from the cylinder is looped back to the extend end to speed up dump. All down stream functions are blocked.
  3. The lift work ports send pressurized oil to the cylinder and return oil is sent to the power beyond port where it is available to power down stream functions.
Based on that and your description something is blocking the downstream flow of oil from the UP side of the loader valve/cylinder. The loader cant lift because oil flow is blocked and the the 3pt will not operate for the same reason. The most likely culprit is the quick connect coupler on the UP loader valve port.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,500
1,949
Western MT
I would check the hydraulic fluid level, grease the FEL, and if you haven't changed the hydraulic filters in a while do that and/or change out the hydraulic fluid if it is due or past due.
I'd also look at the hydraulic cylinders/rams to make sure you haven't bent them.
GunnerBob
Apr 3, 2011
9
Utica, OH
That makes sense to me. Thanks.
GunnerBob
Apr 3, 2011
9
Utica, OH
Thanks for clarifying.
GunnerBob
Apr 3, 2011
9
Utica, OH
First, thanks to Henro, whitetiger, RCW, TheOldHokie, & jimh406 for all of the quick replies, especially on a holiday.
Also, I am so grateful for this forum and the many resources you all have compiled. I was able to find the part number I needed pretty quickly, and gave it to my Kubota dealer. They had them in stock, and my tractor is back working!
I ended up replacing the female quick couplers on the white & yellow hoses, as recommended by whitetiger, RCW, & TheOldHokie. That did the trick.
Thanks again…without your advice my tractor would be awaiting an expensive trip to the shop, I think.
Gratefully,
Bob
severtki
B3300SU w/LA504
May 28, 2015
24
10
Ann Arbor, MI
Same problem here, but the fix of replacing the white&yellow quick couplers didn't work for me. Started a fresh thread here with my question:
Kirk
Brettski
B3300SU
Nov 29, 2022
9
Maine
I would like to add my thanks to everyone who participated in this discussion, including the OP. I have the exact same tractor with the same symptoms. This thread helped me fix it.
The only issue I ran into was that the new female couplings, despite being OEM and made in Italy and looking exactly like the ones I was replacing, had slightly less taper on the threads. I ended up snugging them down to the point where they were really pinching the colored cap rings. But no leaks, thankfully! 😅
8,193
That's probably because one fitting is probably NPT and the other is BTPT.
You really should get the right fittings.
