coachgeo
Want to have a Get Together with other orange owners... maybe have a regional wrenching weekend to assist each other with modifications, Fabrications or repairs etc... Then join a Regional Group.
See http://www.orangetractortalks.com/forums/showthread.php?t=31393
Manuals etc. for Implements See Ultimate READ ME in Service & Repair forum
Searching Kubota<.>com and Messiks for implement parts. http://www.orangetractortalks.com/forums/showthread.php?p=233649#post233649
Spec's etc.
. Details of the three different Categories of 3pt attachments (Cat 1, Cat2, Cat3)
http://www.orangetractortalks.com/forums/showpost.php?p=152433&postcount=19
http://www.orangetractortalks.com/forums/showpost.php?p=165507&postcount=4
. Drawing w/Measurments SSQA for Kubota. SSQA plates and dimensions are a standard spec for all SSQA devices, that makes them universal for tractors and skid steers. Their may be different standards over the years. Check this when looking at age of SSQA plate and age of what it will go on*
http://www.orangetractortalks.com/forums/showpost.php?p=153538&postcount=2
* http://www.orangetractortalks.com/forums/showpost.php?p=153662&postcount=12
Where to get a FEL for new to older tractors
Coldwater Tractor (AfterMarket loaders for older tractors, presently no website)
36zero 5three2 713one and 3six0 five33 2one60
Leon Manufacturing- Aftermarket loaders for our older Bota's. Not aware of a range of cost for theirs
http://www.leonsmfg.com/
Bush Hog- high-end dollar and cents wise?
http://www.bushhog.com/catalog/quicke-loaders/
SSBTractor Around 3 grand?
http://www.ssbtractor.com/tractor-front-end-loader.html
Used reconditioned Loaders / FEL's (Info from craigslist ad )
http://www.orangetractortalks.com/forums/showpost.php?p=174620&postcount=1
*For Fabricating FEL's BackHoe's etc see sticky in FABRICATION forum
Do your FEL arms look like they are spreading??? Some apparently have
http://www.orangetractortalks.com/forums/showthread.php?t=28757
Front 3pt Hitches
Links: http://www.orangetractortalks.com/forums/showthread.php?t=21698
DIY and Maintenance of Attachment/Implement
. Dissasembly-Reassemble Hydraulic Ram
http://www.orangetractortalks.com/forums/showthread.php?t=28433 First couple of post show how to remove piston/shaft and post 16 discusses reassembling
. THOSE PESKY PULL CABLES ..... how in da helz do you lube them (compression release cables, Throttle Cables, Choke Cables etc.)
http://www.orangetractortalks.com/forums/showpost.php?p=155249&postcount=12
Spec's etc.
Front 3pt Hitches
