UDT or Hy-gard
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,220
141
Coyote Flats,Texas
Due to the fact that I own a larger JD tractor that I utilize Hy-gard hyd oil in it I'm thinking about changing my Kubota M7040 HDC over to utilizing Hy-Gard so when changing to different equipment hyd oils won't be intermingled between tractors/equip. Any thoughts about my idea?
Thanks,Jim
3,329
What equipment?
Magicman
Oct 8, 2019
5,752
8,417
Brookhaven, MS
knotholesawmill.com
Your concern sounds very legitimate because you are "swapping spit" with every hydraulic cylinder equipped implement. I have the exact same concern with a John Deere and a Kubota sharing implement duties.
Bmyers
May 27, 2019
3,393
4,138
Southern Illinois
Is there that much of a difference between the two to make a difference? I'm asking, because I really don't know. The amount being mixed wouldn't seem to be that great and I don't know there is enough of a difference between the two products to worry about it.
SidecarFlip
Banned
557
So long as the Kubota isn't a hydrostat, you are fine. If it's a hydro, not fine. Hydrostat drives (Kubota) require a specific additive package or so I'm told. gear drives don't. I run Chevron THC Synthetic in both my gear drive, hydraulic shuttle M's and always have. I like to run a standardized fluid as well and it's cheaper in 55 gallon drums anyway.
Both of mine get Shell Rotella 5-40 synthetic T6 for engine oil and I always use Kubota filters exclusively.
Since 2004, no issues what so ever.
If I'm not mistaken, the Deere fluid is a bit thicker than the Kubota fluid but I'm not 100% sure. I've seen them both and the JD stuff pours a bit thicker.
BAP
Dec 31, 2012
2,867
957
I would suspect that you would be fine. John Deere runs that fluid in their hydrostatic dozers and tractors. It is a good oil. When I farmed, we used it all our equipment because we had Deere, Ford, Case and Case-IH.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,220
141
Coyote Flats,Texas
Equipment I was referring to about changing between tractors were rd hay baler,disc mower & bi-fold wheel rake.
Jim
