I have the factory shop manual and am doing my 50 hour service on my HST L3700(basically an L3400). Bought 2010.
Other than that, not a bad 50 hour service !
Rich
- The second clutch adjustment is behind the FEL mount. I have no clutch problems and am wondering if I can go out to 100 or 200 hours before checking. Is this even important to check on an HST model if I'm having no grabbing or slipping ?
- The manual shows grease fittings on the front of the axle at each outer end. Mine just has threaded holes (previous casting holes where the grease fittings would have threaded in?) and using a metal pic shows there's no hole in there, just metal at the bottom of the holes. Was the front end changed somewhere along the line to no grease fittings?
Rich
