turbo 05 series engine
thebash1
b2023
Jan 24, 2023
sedro woolley wa
I have a little research to find that there is not much difference between the d1105 and the d1105t other than the turbo and maybe rings. There are atv kits and they come stock on tractors and bobcats. Here is my question. The d1305 apparently is a d1105 with more stroke, same everything else but crank, and I have not found any factory applications of a stock turbo on the larger stroke engine, and am wondering if that negatively affects the addition of turbo?
MOD NOTE: ( You get one thread / Post on this subject not 5, I've deleted the rest of the posts )
5,133
First what is a B2023????
Do you have a B2320?
And is this the tractor engine your trying to turbo?
If it is then it's not a D1105, its a D1005
Second, I don't think the stroke changes between these engines.
If they are like every other series of Kubota engines only the bore changes.
And there is just about any configuration to these engines being non turbo and turbo.
What do you mean by ATV kits?
