Trashed L275
Rotndog
L275
Dec 31, 2016
Washington
Hello everyone. I just picked up a L275dt. It's in such bad shape that I almost passed over the ad. I decided to give it a second look. Most of the wiring is melted. Every cylinder on the loader and backhoe leaks. The tachometer is missing. Someone rewired the dashboard wrong. Needs a hood and seat. The pins on the loader are replaced with bolts that are too small. Fuel system leaks. And the list goes on. I started it up and despite all the problems, it still works.
Now that I have it home, the fun begins. I will start with rewiring it, fixing the fuel leaks, and some basic maintenance. If anyone has extra parts let me know.
I have been searching this forum for a few days and was able to locate a parts book and repair manual. Thank you to the people who posted those links. It makes my project much easier.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Post up your build pics and actions. We love seeing an oldy goldy come back to life.
rbargeron
Jul 6, 2015
1,185
262
western ma
I;m guessing the hydraulics haven't been treated any better than the rest of the machine, so after the leaks are fixed the best favor you do this rig is a full fluid replacement.
Run all the hydraulic cylinders to full-retracted, and drain all that will come out the bottom trans plug. Put 2 or 3 gallons of new oil in the trans and cycle all the cylinders a couple more times to change (dilute) the old oil left in the system. Drain it again, clean the bottom suction strainer, clean/replace the hydraulic filter and put in new fluid. The machine will thank you for years.
