Transmission lever function
Shaneb
Kubota B7100E
Jan 22, 2022
What is the function of the top orange lever in the picture. Bottom is 4x4 next up is high and low and top is?
2,897
Never seen that application - but this is a SWAG - seems that you have aux hydraulics for something else you are using, that lever seems to control the flow or direction of the fluid. Are those for rear hydraulics?
Can you take a picture by pulling away a bit ? Show more of the tractor, it may help determine what specifically that does.
Shaneb
Kubota B7100E
Jan 22, 2022
The hydraulic hose on top is just a return from the hydraulic valve for the dozer. It seems to have 3 positions and definitely seems to have something to do with the transmission, it feels like it's shifting something. It has no effect on any speed or direction or the rear pto. It doesn't have a front pto that I can tell.
Shaneb
Kubota B7100E
Jan 22, 2022
I thought at first it may be a creeper gear.
2,897
Digging a little deeper ............. that should have a speed control , MUCH like a creeper gear
2,897
similar set up......
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
684
292
Herald Calif.
That is a creeper gear set up. Normally installed when using a trencher. These were installed by the dealer on the early B7100. The original transmission cover was removed and this unit was installed.
Shaneb
Kubota B7100E
Jan 22, 2022
That's very interesting, it definitely seems to have NO effect on the speed, I've shifted it while moving, definitely feels like gears but no clashing. I'll mess with it some more when I get it going again. Rewiring it now. Thanks for all the replys!!!!!!
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
846
757
E.
I have a copy of the owners / users manual for this tractor but trying too attach says too big. 8mb I could send by e-mail I guess just let me know,
If I remember right the highest lever is an add-on after market on-off for hydro circuit.
kubotafreak
Sep 20, 2018
1,049
398
Arkansas, US
My b6100 has a lever like that for 4wd engagement. Granted its in a lower spot...
