Trailer deck life
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
321
27
23
Mobile, AL
I bought a new 20’ trailer less than 5 years ago. I’m disappointed that I now have multiple rotted boards that must be replaced. The trailer lives outside in the weather but so does my deck at my house. I even put a few gallons of Linseed oil on it twice. Maybe I’m being unreasonable that I have to replace 30% of the boards on my occasional use trailer.
WAS BANNED FOR NSFW PICS
5,160
Do you use the trailer in the winter when the roads are salted? Salt will destroy wood quickly. I have no idea of what wood the trailer manufacturer used when the trailer was manufactured. In the old days, truck bodies were covered with white oak planks, as well as other hardwoods. They lasted forever. Back then, the underside of the body was painted with a heavy weight oil to protect it from the enviorment and the salt. The top side was untreated, so it would be safe to walk on. The boards were about 3" thick, and held down with carriage bolts, with the ends of the bolts deformed with a hammer after the nut was tightened, to keep it from backing off.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,441
1,735
Kalamazoo, MI
Replace it with rough sawn white oak. "Treated" lumber is junk unless it's treated with creosote.
BX23-S,57 A-C D-14,
5,893
I've built a lot of trailers in the past 3 decades, and still have one with the original PT deckboards, in fine shape. They're OLD lumber( 30 yr+-) NOT new ones. 'they' don't make good lumber out of trees anymore,even so called #1 grade is maybe old '#3' at best. that's the first problem.
2nd is install and maintenance. You MUST treat the ends and any cuts with 3-4 coats of preservative AND be sure there's a gap between the boards ! ANY 'standing ' water will eventually rot a board.
3rd. clean the trailer top and bottom !,keep deck tilted,in the sun and wind. If it's dirty and under trees, moisture invites mold and bugs and rot......
Thunder chicken
M7060
Dec 29, 2019
300
123
Northern ontario
I agree with the rough sawn lumber. We cut a bunch of Tamarack (Larch) for a fellow who was using it for heavy equipment float trailers. I’ve also heard (surprisingly) that Poplar once dried makes a tough trailer plank. Plus, you’d be supporting a local Sawyer not the scam artists making up the retail lumber mafia
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,714
2,153
Western MT
I don’t know what your environment is like. Around here wood lasts a long time, but it is dry here. According to my trailer builder, most trailer boards are installed too tightly and have a tendency to never dry out. He does like to stain boards though similar to a residential deck.
BAP
Dec 31, 2012
3,065
1,188
Do you keep the deck clean? Dirt left on the boards will make them not last long. My trailer was built 30 years ago with pressure treat lumber and it is still original boards. Environment is pretty harsh here.
old and tired
L2800 HST; 2005; R4
That life in the south!!!! I've replace my deck 3 times since 2005... Just look at our forests, a tree falls and you can watch the tree disappear over time. We just replaced a deck on our work trailer that sits mainly under a 3 sided shed.
If you don't like doing that buy marine grade pressure treated wood for the deck.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
554
318
Mandeville Louisiana
Be reminded that all treated wood is not the same. I fortunately live around New Orleans and can readily get marine grade (.8 and 2.5 CCA) treated lumber ( rough and smooth), I use it for everything house sills, bulkheads, wood racks, trailers, wall plates, etc.
PaulR
Aug 3, 2020
581
460
Hadley, MA
5 years? <shrug> seems pretty good to me, but I live in New England.
Tried Messmers UV Plus on my deck I installed a year or two ago, seems to be working quite well.
Donystoy
Dec 10, 2013
690
326
Binbrook, Ontario
The original spruce boards lasted about six years on my trailer before they started to rot on the ends. I replaced them with pressure treated and they have already lasted longer than the originals and are as good as when I installed them. Not long after I installed them they dried out and shrunk enough to leave about 1/8" between them which is good and allows them to shed water. I have 3/8" plywood sheets that I temporarily lay over them if I am hauling fine material.
6,141
Wow. Hard to believe that you guys aren't getting more life out of your deck boards. I'm going on 16 years with my originals (oak). I stained them once (after about 7 years), and treated them to a healthy coat of used motor oil just last year. I'm planning on doing the used motor oil from now on maybe every other year.
I do make sure that there aren't any leaves or pine needles left on it over winter.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
You would be better off treating the wood with tung oil than linseed oil however what would be better is if the trailer was decked with ground contact pressure treated wood. I've got one I put pressure treated wood on about 12 years ago and with the exception of a few oil leaks from equipment haven't treated it with anything.
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
319
107
Nicollet, mn
apitong is what you need if you can find it and afford it. Best wood flatbed floor out there. Comes from the Malaysian rain forest. The stands of it in this country were depleted a long time ago. The suppliers store it as logs and cut dimension lumber to order. When working with it if you get a sliver it burns. Heavy and strong
2,506
See this website for a good discussion on grades of pressure treated lumber
I know that the pressure treatment leaves the wood very wet and you can buy kiln dried after treatment (KDAT) but I have no idea what grades of KDAT are available.
Since you are in Alabama there are probably more local suppliers to your area with similar products.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
263
64
Southern IL
Have a 1997 utility trailer that has the original CCA treated yellow pine deck. Coat it every year with used motor oil. Boards are worn with cracks, but no rot.
I disagree with comment made about salt deteriorating wood. Certainly the metal fastenings can corrode, which in turn will damage the surrounding wood. Think they call that iron sickness.
