My B2100 almost isn't moving anymore. Problem evolved out of the blue when I was doing some brush cutting with a rotary cutter attached. I inspected the tractor for the obvious (leaks, oil levels, mechanical issues) before I decided to move it back from the field to the yard for a deeper dive into the problem at my shop. There was no obvious cause for the problem. On my way back from the field, the problem increased to get worse within five minutes. Up to the point, were the tractor wouldn't move at all (tractor at working temperature).
What I did so far:
- checked the hydraulic oil pump (seals and wear)
- checked for the proper clutch adjustment
- checked for leaks -> seal of mid-mount PTO is leaking slowly
- tested the influence of moving oil through the loader circuit while trying to drive (I thought, maybe I can recognize even more of a power loss, but no. No influence at all on the driving issue.)
- tested, if driving issue differs between oils being cold, in comparison to the oil being warmer: turns out the tractor will move slowly until oil is warm, than no "power transfer" to the wheels and this weird rattling sound (check the attached video)
Video link here: Tractor Video on Rumble
Specs: Kubota B2100 HST
What I did so far:
