Tractor Size Advice
Hammer10
L3130, Z725, L3901, L3560
May 29, 2014
Cookeville, TN
I have an L3130, looking to add a larger unit. I have looked at the L5060 & L6060. I want to be able to pull at least a 6' bush hog or 7' finishing mower and possibly a 4X4 baler. Any recommendations?
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I'd buy the implement and give the L3130 a shot at it. I would not hesitate to put a 72" bush hog on my L3200.
TripleR
Sep 16, 2011
1,911
SE Missouri
I had no problems using a Land Pride RCR2672 with my L5030 HSTC. I now have an L5740 HSTC and really can't tell any difference, both had more than enough power.
I have no experience with a baler.
Wingcutter
Kubota M7040HDC 4X4 Exmark Lazer Z DS-Series with Kubota D-902 engine
Jun 7, 2014
EL Dorado,Arkansas
I use to have a 2007 MX5000 4x4 with R-4 tires and had no problem pulling a heavy duty 6 ft rotary cutter or an 84 inch maschio finish mower. 44 pto hp.
Stubbyie
879
Midcontinent
Unclear what the 4x4 baler you mention actually is: a small round or large square baler. Local nomenclature varies nationwide I've found.
However, your L3130 should easily operate a 6-ft shredder aka brush-hog. But as in using any shredder the terrain (ground speed), expected quality, and material being cut (lawn, pasture, undergrowth, brush, saplings, rocks, stumps) make all the difference.
Bluegill
Jan 11, 2012
1,559
Success Missouri
My L3800 pulls a 6 foot rotary mower just fine, not sure what the baler would require? I'd be looking at a L4600DT or MX5100DT.
BAP
Dec 31, 2012
3,028
1,141
First thing to do is to find out what the HP requirement is for the round baler. Then find out how heavy it is and how heavy of a bale it makes. You want a tractor that is going to have enough power and weigh at least as much as the combined weight of the baler and a full bale in it so you are not being shoved around by it. Most of the tractors people are suggesting in the L series are probably way to small for what you want to do. Particularly if you bale on any type of a hill.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I would not be as concerned about the bushhog or the finish mower. The baler will be the biggest load so if you know what baler your going to use match the tractor to that.
I agree with Gundoctor though, the M7040 or 7060 would be a good starting point. Depending on the baler requirements you may have to step up to a 90+ hp tractor. If I remember right my baler requires 70 or 75 PTO hp. I know in good hay it gives my M9000 a healthy workout. You don't want to be underpowered pulling a baler and you need to have a tractor heavy enough to handle the baler safely in all conditions.
moondog933
M7040,Landpride Cutter RCF 2784,FEL LA 1153,FORKS PFL 3048,John Deere MX10
Jul 26, 2013
15
oberlin, la.
M 7040 with dual remote outlets....don`t forget to add the a/c cab :d
between the flags
Pennsylvania
I have a kubota l3130 with 3500 hours on it and it still run good bale hay with it and lift 1200 puns round bales with it I have 3 remote valves and I run a kubota disc mower with it it also runs a 7 foot king cutter mower fine in high brush
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I can see no problem with the mower and lifting round bales. What size disc mower and baler do you use. I would have never thought about a tractor that size having enough power or weight to handle those jobs.
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
Just to add something about bush hog requirements. I can see some of the 30-40 hp tractors running a medium duty 6' mower in weeds and light brush. I have an M5140 w/6' LandPride cutter and have no problem having enough power to get through most everything (weeds/brush) with the exception of tall Argentine bahia grass. Even when gearing down it still builds up clumps of grass and can bog the tractor down to a stall. The back of the mower can be raised to a point that helps the movement of the material out of the mower. The front of the mower is set 1"-2" lower than the back. I don't like the design of the mower because there's not enough of an opening in the back to get rid of grass quickly. I guess my point is that if you don't cut super heavy grass you should be fine with either choice.
