Mike3656
Have grader blades, disc, assorted plows, cultivators, rotary cutter, rotary til
Hey guys,
I just finished my new tool box on my new L4600.Simply remove the plastic one that came on the tractor and buy your desired size military sealed ammo box, drill holes in the bottom, spray paint to match and bolt it in place of the plastic one. Cheap, durable, dry with rubber seals and will hold needed wrenches, hammers etc. that you need when in the field. OH!! The plastic one is painted and mounted on the brush guard to hold 3 point hitch pins, complete set of small mm end wrenches, ratchets and sockets, whatever...new ammo can <$20.00. Cheap and looks great !!
Does anyone know where a kit can be had to allow remote actuation of the lift lever from the rearward ground level, like on the Kioti tractor...???
