tool box
tonyvkubota
2013/B3200HST/L504 loader/60" rotary finish mower/ 60"brush hog
Dec 14, 2013
72
ny
Can anyone offer any ideas for a tool box that I could make fit using my three point hitch on a B3200 ? Something big enough to hold a chain saw, oil, fuel , wedges, slings etc. My thinking it be better than towing a small utility wagon. Hoping maybe something I could buy. I do not have machineing equipment or welding equipment at my disposal , but might be able to have a shop make something if I had some ideas from here.Any suggestions be appreciated.
7,084
Maybe a Carry-all?
TSC sells the metal framework - add wood parts/box as you see fit.
Fallon
L3200
Sep 10, 2013
19
Parker, CO
Pallet forks, then just throw everything on a pallet. More for the front than 3pt, but a caryall can pick up a pallet too.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
tonyvkubota
Dec 14, 2013
72
ny
Maybe a Carry-all?
Ok, that looks like the way to go for me. Some pressure treated wood, little carpentry skill ( and I have only a little in the carpentry skill ) and I can make just what I want. A wagon going thru the woods, backing up in tight places is just annoying if not needed. Thanks for the idea. I will be making use of your suggestion.
tonyvkubota
Dec 14, 2013
72
ny
Maybe a Carry-all?
OK off to tractor supply , then a bite to eat in Roma' s on the way back. Thanks again
JGL
L2250,bushhog,cultivator,woodsplitter,buzzsaw,farmi winch,woods blade,harrows,
Feb 17, 2013
14
Dieppe, NB,Canada
Had the same problem as you have, it took me 30 years to build a carry all, one of the best implement to put on your tractor. You put it on when you need it, take it off when you don't. I built mine with 2'' angle iron with 2x10 and 2x4 pressure treated wood
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I built a rectangular frame out of angle iron, 1-1/4 x 1-1/4" and laid a piece of 1/2" plywood inside that, At the front corners I had sufficient plywood cut-out that the hooks of the Harbor Freight quick-hitch fit in there. Then at the rear corners I had a loop at each corner made of 3/8" diameter rods. Attached to those loops was a light chain on each side. On each end of the chain I used those closed type latched chain connectors looking like mountain climbers use.
Then on the upper corners of the quick hitch frame I welded on loops so hooks from the chain could be attached there. Thus, the platform is supported on front by the hooks of the Quick Hitch and at the rear by the chains, adjustable. Since I had given away both of my good welders when I moved to the city, I went to Harbor Freight and bought a $100 wire feed welder. With that cheap welder I did all the work. It only welds light stuff, but it worked. These welds don't need much skill. This platform is also used for carrying wood to the cabin for heating. Is easily taken off and easily adjusted. Measurements about 3 feet wide by 3 feet to the rear. One added feature not really needed was an extra angle iron down the center in case the plywood sagged. Much lighter than fork lifts and pallets. You could add sides to the platform to keep stuff on it better.
Steel came from a local steel supply house. However some hardware stores sell it also.
In the past, I carried chain saws in a scabbards made of plywood attached to convenient parts of the tractor.
cerlawson
Feb 24, 2011
1,067
PORTAGE, WI
Beginner welder, practice first on scraps. Don't use their welding wire, but get some known brand wire, smaller size. This cheap welder does amazing and needs a 20 amp 110v outlet. Even comes with a cheap, but OK shield.
tonyvkubota
Dec 14, 2013
72
ny
Had the same problem as you have, it took me 30 years to build a carry all, one of the best implement to put on your tractor. You put it on when you need it, take it off when you don't. I built mine with 2'' angle iron with 2x10 and 2x4 pressure treated wood[/QUOTE
Yes I see others here thinking the same general way. The replays gave me several good ideas. Thanks too all for the good ideas. I will be busy building soon.
9,578
If you really don't want to have to do heavy fab work.
Get a 3 point hitch.
And a receiver tool box. ;)
cerlawson
Feb 24, 2011
1,067
PORTAGE, WI
The attachment shown with the 2 inch square receiver is great. However, any of these three point tools usually is much better used along with the Quick Hitch as sold by harbor Freight and others. Get that and you will be pleased. For instance that triangular attachment can have a couple of 1" bars welded on to serve as a cleat for attaching a rope for when you want to pull over a tree that is about to fall the wrong way. Weld on some grab hooks and you have a place for chains for dragging logs. The, the obvious. Backup to a trailer and ease your ball hitch up under the trailer hitch and away you go, staying on the tractor all the time.
tonyvkubota
Dec 14, 2013
72
ny
Ok, got some great ideas from all the reply's. Basically going to take part of several reply`s and put them together for what I like to make for a tool box. I will post the pictures when done in a few weeks.
Thanks to all for the great suggestions . All the suggestions gave me a plan now what to do for a tool box. THANK YOU TO ALL
