Tire chain tension
rparkinson
297
Northport Maine
I have a new set of chains for my L3200- front and back- how tight should I run them on the front so they dont walk? I have never run fronts myself, but I hear that can be a problem. I think it will work good up here in maine. I am on the coast so we get alot of wet heavy snow and ice....
9,878
Tight, One trick to use, put the chains on and tighten run it around a little to set the chains, deflate the tires down to about 5 psi, retighten 1 link air tires back up to max pressure.
Also use high quality rubber tensioners on the outside, it's always better to have a set of chains come off to the outside rather than the inside.
Orange Tractors
Jul 19, 2009
323
Butler, MO
I have never ran chains on the front of a tractor; but I have ran chains on several pickups, including the front of four wheel drives. I never bothered buying the actual chain tensioner, and never had a problem.
What I do is mount the chain (preferably before you are in mud and stuck:eek:) hook the inside adjuster one link shorter than the outside and use rubber tarp bungee cord to tension. Then drive on it for a short distance before tightening with the outside chain.
Rig the bungee cord in a figure four and it works very well.
Robert
9,878
I used to do the same thing, but now I can get the "proper" chain tensioners at cheaper prices than the bungees. :cool:
