Recently repaired a L2850 with LA650 FEL. I installed a two way single spool valve for use with bucket grapple. Pump line from tractor supplies FEL valve,Power beyond from FEL valve supplies third function valve. I have third function valve tee'd into return to tank line with FEL valve, and Power beyond from third function running back to tractor. This setup is working well so far. I do not have PTO function for three point hitch, which I believe this is the way system should operate. I want to hook up my Bradco 8M2D backhoe. My question is can I plug into circuit downstream from third function valve or should I plug in after FEL valve?Do I need to Tee Power beyond line?
