Temp fork extensions
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
First let me say these were for one job and a light one at that I needed to move a 2000 gallon plastic water tank . I didn’t want to try and pick it up with the 4’ Forks as I didn’t want to damage the tank. I tied 2 1/4” square tubing on the forks with 2000 lb test mule tape. We had to replace the water tank as it was slightly damaged during the Thomas fire last year that burned through our ranch the top sagged but it doesn’t leak. I’ll use this tank to supply a water trough for the deer. Where there’s a will there’s a way.
Yooper
3901 LA525
May 31, 2015
1,674
834
NE Wisconsin
I nominate you for the Red Green duct tape award! Whatever gets the job done, right?
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Schedule 80 pvc slipped over the forks works in a pinch also
bcbull378
Sep 6, 2011
579
32
Ventura Ca
I nominate you for the Red Green duct tape award! Whatever gets the job done, right. Thank you sir I***8217;ll except it proudly
shootem604
Apr 23, 2018
874
British Columbia
Steel rectangular tubing about 2X10 cut from an old mobile home hitch works well too!
