Take a guess what the problem was
motionclone
May 4, 2018
1,399
996
Maine
Spent the last 3 weeks trying different solutions to getting this tanaka leaf blower working, finally figured it out.
Whats your guess at the problem?
Ran great when parked, couple weeks later no start, no fire.
-Gss good, changed carbs to a new one, still nothing.
-Checked spark, good spark. Put in new plug anyway, good spark still no start or fire.
-sprayed with ether, still no start not even a little cough.
-did compression check, throttle wide open 130psi, still no start
-changed fuel lines and tank filter, no difference.
-air filter was dirty but removed during the troubleshooting so not a factor.
Fixed the problem in about 60 seconds, started right up.
What do you think was the problem
bucktail
Jun 13, 2016
1,276
198
MN
If it didn't fire on ether must have been spark. I'm guessing kill switch.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
Mine was a clogged spark arrestor screen, but it would monentarily run and then die.
motionclone
May 4, 2018
1,399
996
Maine
Mud daubers decided to call the muffler home?
Bingo
The spark screen was clean but the pipe which is about an inch long was completely plugged. The mud was far enough back from the exhast opening that it was hidden.
I almost threw this thing away to get it off my bench.
Mark_BX25D
Bx25D
Jul 19, 2020
1,937
1,421
They did that to a saw of mine. The P.O. had modded the muffler, and had not put a screen in the outlet. They got in and set up shop. Plugged the ENTIRE exhaust port. Solid.
The good tjhing was that the piston happened to be in the up position, so they didn't get into the cylinder. Took a while to get it cleaned up.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,441
1,735
Kalamazoo, MI
We don't seem to have issues with those in West Michigan. Are they not found around here?
motionclone
May 4, 2018
1,399
996
Maine
Been there, done that. If I had seen this posting earlier, I would have told you what the problem was ;)
I own 1 leaf blower, 2 weed wackers, 2 chain saws, 2 rescue saws, all with similar 2 stroke engines and tiny exhaust ports and have never run into this problem before.
Pretty sure i read somewhere that mud daubers plugged up a pitot tube on a commercial airplane a long time ago and it crashed. So im all for banning mud daubers now.
